Hi Guys
I am missing the bolts for engine to gearbox.
Can anyone tell me what size they are supposed to be
Ash
G'day Ash,
[Most of this you probably already know, but here goes..
There are 4 positions where the engine mates to the gearbox obviously, but only 3 of them have nuts, the other one is a bolt and a nut..
Looking from the rear of the car - in at the engine, the bolt on your left hand side at the top will be the one without the nut. This bolt is approx.
75mm long. The bolt screws into a thread on the case.
The Bolt that goes through the starter motor is approx. 120mm long. It has a nut around behind the fan shroud.
Sorry, i can't help too much with the bottom bolts, but hopefully someone else will be able to. The 2 bottom positions have the studs coming through
from the engine. There are 2 nuts that bolt on the underside of the gearbox.
Cheers,
Denver
Bottom bolts are studs only.
Sorry, will update top post.. was doing too many things at once
Thanks guys
