Reversing light question
baghall - September 17th, 2015 at 08:35 PM
Is it normal for the reversing lights to come on when slipping through the gate for 1st and reverse in a T25 wbx, or is my switch positioned wrong?
psimitar - September 19th, 2015 at 05:48 PM
Do you mean when you put the box into 1st the light comes on briefly?
Special Air Service - September 19th, 2015 at 08:01 PM
not sure....on mine the reverse light wouldn't stay on unless I held the shifter as far left as possible, if I let it go it would switch off.
I had to remove the washer between the switch & the gearbox to allow the switch to screw further into the box & then it would stay on.
Possibly you may need to do the opposite & add another washer or a thicker one?
baghall - September 20th, 2015 at 11:47 AM
Originally
posted by psimitar
It stays on in both reverse and 1st until I take it out of gear.
psimitar - September 20th, 2015 at 12:31 PM
Originally
posted by baghall
posted by psimitar
OK, so IIRC the switch has a spring loaded plunger that when in the detent for reverse on the hockey stick makes the switch earth as the plunger is
fully extended. So If it's fully extended then it needs to screw further into the gearbox. If I haven't remembered corectly then it'll be the other
way around and it needs washers to space it further from the gearbox.
Special Air Service - September 20th, 2015 at 01:35 PM
yeah try another washer and see how it goes.
