Hi all
Looks like my shift rod seal has been leaking a fair bit in the tunnel,
Cant seem to find what it looks like on any manuals ive got
I know the later gearboxes have a removeable sleeve with the seal in it,
What has mine got in it? 65 Beetle
Can i replace it without removing the gearbox?
motor and gearbox have to come out
Yea, gearbox out I'm afraid.
Plus I have one of those seals lying around that I bought just in case I needed for my Ovals box but alas they don't use a seal so anyhoo, If ya want
it then say $5 plus whatever postage is
Mine was leaking too puts a lovely smell through your car. On a positive it's an Auto rust proofer
Thats whats beeen happening Joesbuell,i can smelll it in the car !!
Im up for that seal psimitat
I'll send u a pm shortly
Thanx for the help
Chris
Early boxes did not use seals, ie pre 1967....of course who knows if the nose cone or trans is original!?!
But early trans did have a replacable bush.
Either way, you need to get the bush out, and fit with new.
There are a few different bushes available, early should have a 17mm outside diameter.
While the box is out check the shift bushes and the breather, they are usually the cause of the leak. If the breather is clogged with oil dirt causing pressure build up in the box and the wear in the bushes doesn't do you any favours.
All right then
Not planning on removing gearbox for the moment
So i will live with it and check the fluid level regularly.
Where is the breather?
