Noticed that the left indicator in the T3 is flashing too fast. All globes are working fine. Anyone tell me why this would suddenly start to
happen?
Right side flashes normally.
check the earths on the globes front and rear
also check each globe for corrosion build up underneath at the tabs
Yea, if the bulbs are all flashing then there must be corrosion on a bulb or earth.
