Anyone got a Rivnut tool to lend me
psimitar - January 21st, 2016 at 01:14 PM
Not sure if the right section to post this but just wondering if anyone on Brissy Northside has a rivnut tool I could borrow?
Those pesky M4 screws at the top of the bailey channel were rusted solid and even after careful drilling out the re-thread is way to loose to tighten
a bolt into so thought a rivnut would be the simplest solution.
Cheers in advance
Mike
beetleboyjeff - January 21st, 2016 at 08:27 PM
I have one in Port Macquarie if you can't get one closer. My daughter is coming down from Brisbane for the weekend, and could take it back with her
on Wednesday if you can't get one sooner. I can get it back over the next few months then.
psimitar - January 21st, 2016 at 10:03 PM
Originally
posted by beetleboyjeff
Can it do M4 size rivnuts? If so then unless someone closer says otherwise I think I'll be taking you up on that offer
beetleboyjeff - January 23rd, 2016 at 09:19 PM
Is this what you are looking for?
helbus - January 23rd, 2016 at 09:25 PM
Can you tap the thread up to M5? Then go for a bigger screw?
psimitar - January 23rd, 2016 at 10:02 PM
Originally
Yes, that's the puppy
Originally
posted by helbus
Not really. The metal is barely enough for an M4 thread to have some purchase.
vwo60 - January 25th, 2016 at 01:28 PM
Buy the correct size inserts as they are quite cheap, the unit should have a range of mandrels with it that go from 3MM to 8MM, this is the set I
have, http://www.ebay.com.au/itm/NUTSERT-RIVNUT-INSERT-TOOL-w-MANDRELS-NUTS-4-5-6-8... ebay
has them for a good price. http://www.ebay.com.au/itm/NUTSERT-TOOL-RIVET-NUT-5-MANDRELS-/252240921101?ha...
psimitar - January 25th, 2016 at 01:33 PM
Oh wow, thanks for that. That ones almost half price to those I found when looking on fleabay.
Maybe in the future but just for now the loan will do.
Ta
