Best distributor for 34 pict 3 1600cc combo
ultrasuede - July 24th, 2016 at 08:10 PM
Very confusing using the voogle machine to find the answer to this. I ha e a 34 pict 3 and a 205 vacuum advance dissy. Probably going to go with an electic dissy, but what one? Thanks
waltermitty - July 24th, 2016 at 08:20 PM
you have the best combo available what is your problem with it?
ultrasuede - July 24th, 2016 at 08:49 PM
I cant seem to find this serial number on any references. Its sibgle vacuum, but the 34 pict 3 has 2 vacuum ports
waltermitty - July 24th, 2016 at 09:44 PM
no should only have 1 if there is a second it could be a late 34 pict with EGR port
http://www.angelfire.com/tx2/ntnb/Carb_Instructions.htm
modnrod - July 24th, 2016 at 11:09 PM
http://forums.aussieveedubbers.com/viewtopic.php?tid=104940&page=1#pid982805
Hope it helps.
BRUTUS - July 25th, 2016 at 05:17 PM
The 34 PICT 3 should have ONE vacuum advance connection... Yes Ultrasuede, if you connect the vac. advance properly & it is all working, should be a good combo. as W'mitty said.
If there is another vacuum port, it will be meant to go to the air cleaner (or possibly manifold, just below the carb. mount, on some earlier models? -- why that was done I can't understand). (& the JFUR-4 / 905 205 Z should be DUAL mech./vac. advance?)
hulbyw - July 25th, 2016 at 08:38 PM
Beetles with the later style plastic air cleaner housing needed a vacuum port for the dizzy and one for the air cleaner
BRUTUS - July 26th, 2016 at 11:45 AM
2 pics shown at:-
http://forums.aussieveedubbers.com/viewtopic.php?tid=105590#pid987221
On the 34 PICT-3/4/5, the vac. advance port (a brass tube or spigot) is the small tube on the LHS just above the bypass (large) screw used to adjust the idle speed. The vac port (similar small brass tube) at the REAR (and rear of car) is connected to the air-cleaner as shown in the picture on previous post (link above -- 4-connection type shown -- earlier plastic air-cleaners had two connection points on the air-cleaner).
