Hello,
Has anybody modified an early beetle steering column and added a collapsible section (like the post '68 columns)? Or put a late column in an early
car??
Cheers.
yes I fitted a 76 Golf coloum to my 65 bug
bit of bodywork required to make it fit
ok so I used the top half of the 76 golf and the bottom half of the 65 beetle, but you can adapt the 68 or later collapsible column, the outer tube
will have to be adjusted most important is the distance from the dash to the steering column so you don't hit your knuckles on the dash if yr
fitting different seats then allow for this
I had to cut under the dash approx 30 x 30 cm to have a flat section as the original has bumps and different curves then weld in a new flat
section of sheet metal to allow the new column to be mounted its a bit of cutting and welding. I also allowed enough room to fit a 76 bug fuse
box with the push in blinker, hi beam n wiper modules fitted
the later switches blinkers n wipers have to be re wired to fit the early stuff or you fit later wipers
I am Overseas at moment and don't have access to my pictures so can do on my return Aug 14
mine looks factory and no out of the way bits added very flat dash and unders
