How hard is it to replace the chrome windscreen trim with the screen in place?
if its in a Beetle forget it the c section has to slip into the rubber
Pull the screen leave the rubber on and then fit the chrome trim
I agree with Dave ^^ ...Can't believe I just said that!
have 70s flat screen with ok rubber and gd screen with chrome if u want a repl /spare /bargain $65
saves all the hard yards!
Nice one Greg you could have said Impossible
forgot to say the more you work the trim with your thumbs n fingers the better it will sit when you think you have it right go around the rubber
about another ten times it will move more into the rubber slot
Another trick is to run a bit of glycerin into the slot, before fitting the strip...it's good for the rubber. Chemists sell glycerin.
pull the screen to fit and use liquid soap or Glycerin as per above if its an old rubber lots of luck
what year is the car ???
It's on a 79 cabrio.
