Assembly of rear irs arms
cnfabo - September 16th, 2018 at 02:08 PM
Hi guys, I'm just dummy fitting my rear rotors and custom caliper brackets etc.. When I lightly tighten the hub nut the disc becomes really tight and hard to turn... Any ideas why??? It's never done this before...
Cheers fabo
vwo60 - September 16th, 2018 at 06:49 PM
Do you have a manual and are all of the spacers in there place, I am assuming that the caliper brackets are in place, have you tried tightening it up slowly while you are turning the hub and see if there are any marks where it is rubbing, Post a photo of your set up.
cnfabo - September 16th, 2018 at 07:52 PM
After some tinkering it all came good... Will let u know after final assembly
