This is for all those people that say Kadrons and 1915's are crap. Here is a car with both of those, and it does 12's down the quarter.
Makes those 13sec stroker fuel injected hill climb race cars look slow
http://www.lowbugget.com/
A mate of mine has a set of the AJ Sims stage 6 or 7 heads.
He has a 1776 with 44's and it hauls. California boy...so i havent had a ride in it.
AJ is really getting a name for himself as a head porter.
Worth every penny.
He really knows how to set up them Kadrons.
He also sells a cheap turbo set up for 1600 that is suppose to be pretty good.
"AJ is really getting a name for himself as a head porter."
Yeh. What hotel does he work at?:P
ha ha ha ha ha ha ha ha Plop! - the old laugh my head off trick!
Well at least he doesnt work where my heads were done at - Head Jobs Unlimited! :o
i too have a 1916 and twin kadrons
can someone make mine go that quick?!
Here is what you have to do to make it run 12s....(this is from the shoptalkforums.com website in the type I for sale section)....I guess you can call
AJ Sims if you don't believe the time slip!
FOR SALE
LOW BUGGET.COM DRAG BUG MOTOR "I want a big motor now"
ENGINE/Type 1,
DISPLACEMENT/ 1915cc
BUILDER/ Dave Greiner-Proformance Racing Engines in Orange
CRANK/ DMS 69mm C/W and blanced
RODS/ Scat "H" Beams 5.394"
PISTONS/ 94mm Mahle Notched for 44x38 .125" deep
RINGS/ Deves
CAM/ Engle VZ35
STRAIGHT CUTS/ CB
LIFTERS / Scat Lube-A-Lobe
VALVE SIZE & MAKE / 44x37 Marnel s/s
VALVE SPRINGS/ Erco triples with titanium retainers
PUSH RODS/ Bugpack HD
PUSH ROD TUBES/ Scat Triple O-ring
HEADS / CB044 with three bolt intakes
PORT & POLISHINGS by/ A.J. Sims
COMPRESSION RATIO / 11.3:1
IGNITION /Mallory Uni-lite
CABURATION/ dual Kadrons 47.1mm
LINKAGE /Scat
INTAKE MANIFOLD/ Puma Three bolt
EXHAUST SYSTEM/ Berg 1 5/8" with O2 sensor and suck vent,stinger
FLYWHEEL/ 10.5 LB Rimco
CLUCTH/ Stage 2 Kennedy with 4-puck
OIL FILTER/ O-Berg
OIL PUMP/ Berg
OIL SUMP/ CB 4qt
OTHER / new Bosch alt, bolt on valve covers
DYNO SERVICE/Jimenez Racing
172 Hp @ 7,500 Rpm with old 40x37 heads, now has 44x37
Best 1/4 time with old heads was / 12.57sec @ 105mph
with the new heads it keeps spiting the gear box out.
Motor has less than 20 miles on it.
$3,700 firm
Call 714-538-1145 and ask for A.J
Tie you beetle to the back of one of these!!!!
Works for me!
yes this is a typical STREET car with a typical 1916 engine
CAM/ Engle VZ35 ????
i think stock Kadrons are around 40mm and the engine wouldnt last long at 11.3 : 1
Probally a for gas analyser when tuning.
hey but dont forget these are single throat carbs!
what does berg use on his cars?
well over 50mm dual throats!!!!!!
well im impressed anyway!
That seems like an expensive engine to build. Nice though!
We all know their tracks are down hill and a few feet short
Yes, it's possible - you'll find he's running a leaded racing fuel of about 118 OR and the thing would be utterly undriveable on the street (probably idles at 3000rpm+ and has nothing below 5000 and full throttle.) I know some people are going to jump on this, but venturis are shaped the way they are for a reason - they exist to increase air velocity around the jet at lower revs and partial throttle, while restricting air flow as little as possible. AJ Simms simply machines a single diameter down the center: it increases maximum flow, but must play hell with any lower air speeds. I think any of us that could afford to spend the money such an engine cost would do well to spend it more wisely.
I'll have to agree - I would be inclined to believe this time. The motor would have to be in an early beetle (pre 70's) to keep it light,
and must have other mods (maybe gearbox ratios, slicks, wheelie bar ?)
With triples and the bottom end that motor has got, it should pull the 7 or 8000 revs hes talking about. Must have an *evil* cam in it though.....
47mm kadrons... obviously not stock eh ?
3 bolt intakes indicates a serious port job.
172 hp from 1.92 liters = 89.6 hp / l, which is excellent for a 2V per cylinder, air cooled motor, but still certainly believable. People get over
200hp from their 2.1 - 2.4 type 4's, which is a similar sort of volumetric efficiency.
conclusion - nice drag motor, but street car I think not.
A Vw powered car that is considered quick, perhaps a little undriveable , so tune it down.
Stay with the 1915 cc formula "as its proven to be a winner" but tune it for more driveability. ( and a lot more reliability) .
Glenn
Nuthing wrong with the 1916 94 x 69
its just the Carbies... n compression ratio:vader:vader
