vrommmmm mmmmmm mmmm vrrrr
de_ja_vu - September 28th, 2003 at 06:59 PM
hello everybody
i have a very annonying problem, with every touch on the throthle pad the rpm's goes up stays at 1800-2000 rpm's for a few seconds and than drops back to idle.
what could be the reason for that?
any suggestions? where should i check first?
thanx.
555bug - September 28th, 2003 at 07:57 PM
make sure that you have the spring return on youre carb and that it is not obstructed at all.
kombi_kid - September 28th, 2003 at 09:56 PM
have same prob it is mostly in the return springs get some more springer ones
rhys
Peter Leonard - September 28th, 2003 at 10:52 PM
reach down to the pedal and make sure it moves freely :D
fuz - September 29th, 2003 at 09:13 AM
had that prob on my L bug.. i learned to live with it.. but it was the return spring that was the fault..
vassy66T1 - October 1st, 2003 at 03:12 PM
The other thing may be that the cable needs a good coat of grease or it may even be frayed and beginning to catch. A new one would solve it, though grease may be the first thing to try. Too heavy a spring on the carb end just adds pressure to everything
vassy
