Hi guys
Wonder if I could get some advice on DCNFs. ie - fitting twins to my 1835 and would like to know approximate jet sizes to start with and where to
purchase additional jets from. Any help would be greatly appreciated.
you prob need to give more info.
ie. what cam, valve sive, exhaust size, intended rpm etc.
These are 2 sites woth reading on how to jet your carbs
http://www.redlineweber.com/html/Tech/Table_of_contents.htm
http://www.aircooled.net/gnrlsite/resource/articles.htm
I have scanned some pages on DNCF's but it is at work and i am away for 2 weeks. Try Helterskelter or Cray. I believe they both have the pages
As for jetting sizes
Idles - what ever the motor wants. 95% of cases it is a 50 - 55 idle. That said my IDF's want a 40
Read those articles and you will see that there is a sweet spot on the mixture screws. THIS ALONE determines
you idles
Mains should be 4.1ish X venturis size. If you have 32mm vents then a 130ish jet is a good starting point
Airs shoud be 50+ your mains.
So in my case it is 40 / 130 / 180. This is with a F11 Emulsion tube
Your vents are determined by your valve size. They say 3mm small than you inlet or say your exhaust valve.
28mm vents are too small for anything. A stock valved head (35/32) should have at least 32.
A big valved 40/35 should be at least 34 or 36
Where to buy?
Well dunno about Tas but most go fast shops sell jets. A company called Carburettor Service @ Burwood Sydney does mail order. Cant find the # at the
moment
[Edited on 30-9-2003 by blue74l]
can email stuff at your request.
send me a proper email account as one is 44kb & the other is 2mb!!
