Have a slight dilema. Had a cam specially ground for new engine however is early 3 rivet type and not dished. wanted to run 26mm oil pump for full
flow filter and cooler. Do I blueprint the 19mm pump for the cam I have or do I get a new cam and run the 26mm pump.....
Thanks in advance
I think the new cam is the way to go especially if you want to turbo down the track. Go the bigger oil pump.
Hang on have i just replied to my own post or is this just a cheap way to bump.....:o
or as i've found out I could buy a 26mm oil pump to suit a 3 rivet cam. Cool.....
