Rim Offsets
wombatone - October 10th, 2003 at 03:49 PM
What is the maximum offset on the rear of a swing axle bug? (the distance from the bolting surface to the far inside of the rim)
Unity-28 - October 10th, 2003 at 04:24 PM
Depends on whether it has short or long axles.
N!
modulus - October 10th, 2003 at 04:25 PM
Sorry, I don't know the answer, but offset as you have defined it would depend on rim width, and that wouldn't be right.
Offset is usually defined as the distance from the "bolting surface" to the centre of the rim, which is independent of rim width. This measurement on German wheels is often stated as the "ET" of the wheel.
hth
[Edited on 10-10-2003 by modulus]
wombatone - October 10th, 2003 at 04:53 PM
OK, so what is the ET for long axles?
