ive undne the gland nut to remove the flexplate off my 1500 engine but i cant get the plate off . . . . how do i do thid without wrecking the crankcase?
There should be 2 small threaded holes between the dowel holes, Im sure that they are 6mm, just screw a bolt into each one and tighten them evenly and
it will push the plate off.
1302Steve
