steering column`s
wadd - October 28th, 2003 at 06:07 PM
i have a 65 bug and was woundering if i could change column`s with a later model so that i could have the blinker`s and wiper on the column and what model would be best
thanks heaps
shane
Menangler - October 28th, 2003 at 07:28 PM
It can be done, you need a late beetle column,
I used a late type 3 in my old oval but it needed a bit of body work to make it fit right.
vw54 - October 29th, 2003 at 06:12 AM
I used a Series 1 Golf... a fair bit of stuffing around but it can be done.
As Dave said they dont just bolt straight in body work has to be adjusted.
But the end result looks factory and better access to the controls, wipers and high beam switch
wadd - October 29th, 2003 at 08:21 AM
thanks guys. do you use the old shaft or change it to . just so i need to know what to buy . if i figger right i should only have to change the column
Menangler - October 29th, 2003 at 05:17 PM
You buy the whole column. if you use a Beetle one.
