timid timing mark
4 of 50 - December 23rd, 2003 at 06:28 PM
I have just donned the work gear and pre greased the hands when I look at the back of my 77 bus and find no obvious timing marks. There is a mark on the pulley but where is it on the engine. Generator is off to the right hand side and there is a peice of tin attached over the pulley but no numbers I was expecting. Any ideas?
modulus - December 23rd, 2003 at 07:51 PM
I know what you mean....
My Haynes manual reads "The timing mark should read 0 degrees on the scale..." and shows a neat picure of a degree scale which is *not* there on my bus either.
Good luck.
1303Steve - December 23rd, 2003 at 09:13 PM
They are supposed to have a plastic timing scale bolted to the fan housing, I’m not sure if you can buy these anymore, if not someone might lend you theirs as they unbolt very easily. You will also need to find the correct timing mark for your vehicle as they do vary depending on if you have a twin or single vacuum unit.
1302Steve
4 of 50 - December 23rd, 2003 at 10:16 PM
Hmm, I was hoping this was not the case. Should have checked this before soldering myself a yew bewt timing light.
kombikim - December 23rd, 2003 at 10:23 PM
early vehicles had a nicely printed scale of markings which were easily "cleaned" off,
2L motors had a plastic scale, with the markings moulded in, both these scales were fixed to the fan housing by the top & left hand bolts that hold the plastic mesh cover for the fan I dont think you can get them anymore.
11CAB - December 23rd, 2003 at 11:59 PM
I bought one not long ago from Import Advantage here in Brisbane, I think they go for around $20-25
