ROAD TRIP SPARES
robnjo - December 28th, 2003 at 03:13 PM
so if I'm going to use/take my bug on longer trips then normal(dubs by the pub or maybe valla)what sort of spares should I have on board?
#1 fan belt.
*spark plugs,dizzy cap(no points soon...thanks brad)
*fuel line
*electrical wire, tape,fuses,bulbs and connectors
*jumper leads
*some motor oil
*tools (plug spanner,flat & phillips screw drivers,some ring spanners,shifter,crimpers,multi grips???
*rags
*the normal tools (jack,wheel spanner,hub-cap pulls and wheel chock)
*??? so this is where I need help if I forgoten something.
ROB
helbus - December 28th, 2003 at 04:16 PM
Mobile phone. :D
It is they way we live now.
lugnuts - December 28th, 2003 at 05:49 PM
Keep your points,just in case ;)
koolkarmakombi - December 28th, 2003 at 05:50 PM
Points if you use any electronic replacement. Spare drop in dizzy good.
Manual
Lots of water because even though your vw isnt water cooled you are. Stash one of those big lt springwater under a seat.
cable ties, duct tape, s/s tie wire etc
Headlight globes.
:jesus if you are so inclined
:beer or :party if you are not :D
Old Dubber - December 28th, 2003 at 06:41 PM
Spare clutch and accelerator cables.
vw54 - December 28th, 2003 at 07:29 PM
Thats a good listing. Yes include some water as you may need it to cool the fule pump if it gets too hot.
and a funnel for the oil filler tube i hate it when i spill oil on a hot engine.
throw in a couple of tins of spray degreaser from the $2.00 shop.
Starbug - December 29th, 2003 at 10:09 AM
depending on how far and where you are going, a puncture repair kit perhaps? they are good to have anyhow.
and dont forget the WD40!
i also keep a blanket in the beetle incase of unplanned picnics and crap weather, both of which could happen at any time during a road trip.
