year of case?
robnjo - January 4th, 2004 at 03:49 PM
how do I work out the year of my case as its not the original one,my bug is a 71.
any info please
ROB
vw54 - January 4th, 2004 at 05:05 PM
You probally wont be able to work out the year just the engine size.... whats the engine number and prefix ???
robnjo - January 4th, 2004 at 06:33 PM
hey vw54 the only reason is that I'm going to put a full flow pump and they come for 66-70 or71-79.now my case# is AD 327285 if thats any help
rob
robnjo - January 4th, 2004 at 07:12 PM
I'm doing up an order from this mob and I want a spin-on oil filter pump but there are a few.http://store.cip1.com/Merchant2/merchant.mv?
Menangler - January 4th, 2004 at 07:23 PM
You need to know if its a 3 stud cam, or a 4 stud deep dish cam, these are on the later engines
modulus - January 4th, 2004 at 07:45 PM
According to info. at Type2.com, an AD case is a 1600 replacement:
"(Never supplied in new cars -- only sold over the counter. All are
dual-relief with 10mm oil passages)."
no year was given.
hth
robnjo - January 4th, 2004 at 07:56 PM
thanks modulus,hey Dave Becker how do I find that out about 3 or 4 stud,are they the 4bolts/nuts that I can see on the oil pump plate?
ROB
robnjo - January 4th, 2004 at 07:59 PM
FORGOT TO ASK...MODULUS is that a good thing or a bad thin about the case?
modulus - January 5th, 2004 at 06:01 PM
Short answer: Good.
Longer answer: VW had a single, 2-function pressure relief valve which controlled both direction and pressure; they later split this into 2 valves each with one function, thus the "dual oil pressure relief" case. This was not so important, the old relief valve worked fine; however, *at the same time* they increased the case oil passages to 10 mm (from, I dunno, something smaller...) to allow more oil flow to the heads; this is the good bit. Most hi-po Type I engine builders use "dual relief" cases for this reason.
hth
Bizarre - January 5th, 2004 at 06:58 PM
The only way to be sure if it is a 3 or 4 bolt cam is to pull the oil pump and have a look. You cant be sure that it hasnt been rebuilt.
You are going to have to pull the pump for the new one anyway, so......
With the case as well it "should" be a 8mm stud case saved as opposed to 10mm not saved?
This is also a desirable factor. The 10mm studs grew move and pulled out of the none saved case holes
robnjo - January 5th, 2004 at 07:21 PM
ok but when I got the motor rebuilt,the guy said he had to put a new/another case in cause the old one was stuff.it cost me $200 and he said it had case savers...me at that stage said "yeah what ever".but this good right??
ROB
Bizarre - January 5th, 2004 at 08:09 PM
yep
case savers are good
A case with savers and 10mm studs though makes a bad contender for boring for bigger cylinders. 8mm and savers is the choice. 10mm and no savers is last choice
Astro Boy - January 6th, 2004 at 10:10 PM
http://www.type2.com/library/identifi/boxeng2.htm
hopefully this will guide you to the year make. it is accurate for me.
