Just wanted some suggestions for some quality gear box to suit a bug(manual)Do they need anything special? or just your run of the mill gear oil
Cheers Paul
Paul
AC.net recomends Synthetic 75W-90 :jesus
Me - no idea
TTFN
Barry
Castrol EPX 80w/90 :thumb $24.95 from auto one, cheaper at Super cheap
Castrol 80/90 is the best you will get. Buy yourself an 17mm hex socket so you can un do the drain plugs and refill plug.
You will also need a syringe from an auto store so you can refill the gearbox.
Jack up the rear so you can get underneath and the also jack up the front of car so its level then refil the oil in the gearbox until it runs outt he
filler hole and its all done.
Great work...thanks guys
Cheers Paul
