Anyone got any thoughts why the engine may just cut out whilst driving along?
It has happened 3 or 4 times over the last couple of weeks, while just driving along normally at 60km/hr.
It starts up again straight away with a turn of the ignition.
I'm going to give it a bit of a service tomorrow, but any thoughts would be appreciated.
First guess is electrical
Now the hard part - where :jesus
I am guessing a wire is shorting or open circuiting somewhere.
Key switch
coil
condenser
Somewhere in the control circuit.
ie not lights etc.
Try idling the car and jiggle all wires in the key switch, ignition area. The positive to the coil. The negative of the coil to the dizzy
Will try that, thanks for the suggestion.
My Kombi did this then i found that the key switch was worn out and needed replacing
The fuel exit nipple on the bottom of your fuel tank is almost blocked solid. Take it off and you will see what I mean. It happens to all VW's sooner or later.
could be the coil. does it get very hot ???
