hey y'all,
Just a quick question:
How do i lower a 74L bug (not by heaps just a few inches...) But i want it to be REAL cheap... i'm talking REALLLLY REALLLY cheap. Don't
mind if it's a bit of a dodgy job, as long as it still drives well.
thanks y'all.
Yianni :bounce
adz you funny bugga, i like it alot
i've thought of that quite honestly... only problem is.. my 1600 won't be able to handle another 500kgs worth of bricks!
keep buggin' mah man...
btw i wanna see pics of your Bug in progresss!
Yianni.
yeah lowering a super isnt as cheap... i think u have to use lowered struts up front, the back u can just rotate the splines for the torsion leaves
I lowered mine by machining the welds off the strut bottom spring carrier and welding it back on 1 & 1/2" lower.(I think this the max you can go with standard incerts)and lowered the back by turning the tortion bars. Easy and cheep.
