I'm installing a later model AB gear box in my 54 Oval. I know there are different nose cones to fit bugs. I have a 2 hole and a 3 hole. Are there also different types of 2 holed nose cones? I was told a split kombi nose cone would fit? Whats the consesus on this?
TOFU
Is this welding original? or has the previous owner added in a later nose cone mount?
thanks
AB = its the prefiix to the serial number stamped on the side of the gearbox...
does this look like someone has welded in the later mount?
thanks
OK so you have the later gearbox mount already fitted. Some had this style and some had the wrap around dont know why the differences but its
better for you.
I think you will find that a later tunnel style gearbox will fit straight into the chasis. you shouldnt need the Kombi nose cone at all.
If you can get and empty gearbox shell and try that in the hole first to see if it all lines up correctly.
WOO HOO! something's going my way for once! I'll just be dropping the car off to the mechanic for him to do. He's reco-ing my GB
already and its got the later two hole nose cone - should slot right in, otherwise my wallet will hear about it I suppose...
thanks Dave!
