type 4 gearbox's
kombi_kid - November 27th, 2002 at 09:16 PM
hey
just a little question.
i have currently a 1600 motor and gbox running in the 72 panel. I have a spare 1800 motor and 1700 gbox im wondering if there is any gain in putting in the 1700 gbox when i put in the 1800 motor?
is it worth it?
rhys
p.s. whats the strongest kombi box is it a 6 rib 2L?
type82e - November 27th, 2002 at 09:51 PM
Hi rhys
the 1700 gbox has the same final drive as the 1600 I think it is slightly stronger but you know its good and its already in there so might be easier to leave the 1600 box in there
marcel
Doug Sweetman - November 27th, 2002 at 11:40 PM
From what I have heard, the kombi CV flanges are different, so although the gearbox mounting points arent too different (I think) you would have to make up custom driveshafts or change the outer CV's as well.
When I had my V8 kombi, it only had a 1600 gearbox in it. The clutch was hammered, but the gearbox was still good. Treat it right and they are surprisingly strong.
kombi_kid - November 28th, 2002 at 03:04 PM
thanks guys! will check it out this weekend!
rhys
Baja Wes - November 28th, 2002 at 08:25 PM
The type 2 1600/1700 are both the 3-rib gearbox. They both already use the bigger kombi CV's.
For more info read this
http://www.geocities.com/Baja/Dunes/9702/transtalk.html
it's a very good site
kombi_kid - November 28th, 2002 at 09:29 PM
thanks wes! its a good read!
rhys
11CAB - November 29th, 2002 at 05:51 PM
The 1600 & 1700 gearboxes do not have the same final drive.
The 1600 has 8 teeth on the pinion and 43 teeth on the crownwheel giving a final drive ratio of 5.375:1
The 1700 has 7 teeth on the pinion and 38 teeth on the crownwheel giving a final drive ratio of 5.43:1.
Therefore fitting the 1700 gearbox will increase the revs at 100km/h
kombi_kid - November 29th, 2002 at 09:34 PM
thanks!
rhys:vader
