shift sharft
ph billet - March 24th, 2004 at 09:17 PM
is the shift shaft in a 69 bug ment to have a small bent or is it ment to be straight.
70AutoStik - March 24th, 2004 at 11:52 PM
It's supposed to be straight.
Che Castro - March 25th, 2004 at 02:11 PM
do u mean the long rod that connects the tranny to the gearstick?
It is meant to be bent so it can fit around the crap in the tunnel.
that is how it came from the factory. If you think about it, there isnt enough force in shifting gears with a 10mm stud to bend something thats about 20mm in diameter and pretty thick.
ph billet - March 25th, 2004 at 10:01 PM
you have set my mind at eaze I can move on now
[Edited on 26-3-2004 by ph billet]
