I have a case starting with a F my book tells me this is a very good case ,is there others ??:alien
The F case is a 1300 case i think. The best case for a type 1 build is a late dual relief case. They are the ones with 8mm head studs with factory case savers, 8mm studs for the oil pump and other studs. They have larger oil passages.
i rekon if you are gunna chuck a heap of money at go fast bits do yourself a favour and get a new case with all the mods already done at least you dont have to worry about that bit of it,,, old cases are stuffed,,, even if you dont contemplate a hotty it is still worth the investment as it will last not like flogged out old line bored cases.
Yeah i second that. a new AS41 Dual Relief case is the best choice. It is made out of an alloy with higher aluminuim content than the older
cases.
Unless its only a cheap throw together, the price of new cases these days is pretty affordable because of the AUD. A good used virgin case wouldn't
be that much cheaper anyway. Dont support a few thousand worth of parts on an old case.
article on this subject in latest vw australia magazine with stan pobjoy.
yes just got my ( loan ) copy to read .
hey
when building my bro's 1916 it took stan 6 cases to finally get the right one to work on!
go the new alloy cases!
rhys
me fitting ej20 turbo due to cost of vw donk !
How much are the new alloy cases?
Mitchell
depends if you buy here or if you ship in yourself.
They retail here for about $1000......I think !
A lot cheaper if you bring in yourself.
yeah, I secon dthe 'new case with thousands of dollar engine' theory. I have had three cases in 10 years - never again. My new 1916 will be built on a new alloy case - I'll probably have it forever
the alloy cases are about the same price as AS41's on www.aircooled.net actually they're cheaper if you dont get them with warranty . $300 USD
