On a stock 1600 twin port, stock carby and muffler, which dissy is better? meaning more streetable.
Stock motor stock dissy.
I think most people agree that the SVDA (Single vacuum dual advance?) dizzy is best for stock carbies.
Has the best response curve, because it uses both vacuum and mechanical advance.
i have a 1600 SP with a 009 dissy and it has a wackin great flat spot......if the engine is stock then stick with stock components they were made like
that for a reason....i would never have put this 009 on my motor but the guy who had the car before me did it.
Nick
dice the 009, go with stock. had 009 on 1200 and never ever run right ,belched black smoke coughed and farted. now have 1300 with stock vacuum dizzy runs like a dream even with low comp.
stock it is. anyone need a 009?
Need a 009...........Yep, send it my way.
Craig, you have u2u
I have a 1600 single port with Solex Carby & Bosch 009 distributor and NO flat spot...
I did have a 1972 1500 Beetle with solex and 009 distributor & NO flat spot...
Have You timed the 009 at 32 degrees total advance... with the engine revving...
If the flat spot persists, You can adjust the accelerator pump slightly to pump more fuel when the accelerator is pressed...
It IS impossible for a 009 distributor to advance as quick as a stock vacuum/mechanical distributor... as it has to wait for the engine to rev before
it can advance the ignition...
If You have a lightened flywheel, exhaust extractors etc...
You may be pleased with the 009... otherwise stick with what Volkswagenwerk knew...
Lee --
Lee --
I have a type3 with stock 1600tp and 009 dissy
I am really happy so far with it no flatspots runs really well
timimg set at 10dec but will be chaging it to 7. 5 as it is pinging a little under load
marc
