It would appear that SC utes have a different sill arrangement to vans & busses.
htp//vintagebus.com/howto/sc-rocker.html
Also, the rear corners have different shapes.
http://www.dropgates.com
Does this mean that readily avail kombi parts are not suitable?
George,
They are the same profile - just shorter in length. So you can cut down a 'bus' inner rocker, inner strengthener (which strengthens the
outer rocker) and outer rocker panel.
You do have to modify the latch plate on the outer panel - its best to by the ones without the full latch installed cos you just have to remove it
anyway.
Rear corners are different - different shape and they have vents too.
RobK
[Edited on 15-12-2002 by splitbusaustralia]
No vents on a high roof ute Rob, sorry I'm being fussy!!
I consider myself duly slapped down :P
RobK
