stronger axles?
Purple Martin - June 4th, 2004 at 04:53 PM
Is it possible to replace standard bay-window bus axles with stronger ones?
Desert Moose - June 4th, 2004 at 05:47 PM
Yes :thumb
seagull - June 4th, 2004 at 11:01 PM
Why you busting them ??
Purple Martin - June 7th, 2004 at 09:11 AM
I'm not busting them, I want to build a stretch kombi, and I've been told I'll need stronger axles to register it (because of the extra vehicle
weight).
So c'mon Desert Moose, ya cheeky bugger, can you tell me how? :P
seagull - June 8th, 2004 at 12:32 AM
I seen nissan on a kombi once it had a 308 in it does this help ?
Desert Moose - June 8th, 2004 at 12:45 AM
Originally
posted by Purple Martin
weight).
Sorry ...... lol
Are you sure its the axle you need to do to register it. The RTA refers to the whole rear suspension as the rear axle instead of the bit between the
CV’s. Maybe the Torsion bar needs to be done as well. As for the axles I can get racing axle made for you but someone on this forum has some for
sale (say-a-way ones) and I think that’s the go for you as racing axles are over $700 a set.
I hope I have been helpful tis time
Moose
Desert Moose - June 8th, 2004 at 12:51 AM
opps
I was looking for the link on the sway-a-way axles but there for beatle
Purple Martin - June 8th, 2004 at 08:50 AM
Thanks, that's good to know
