(Fuel Filter- FIXED) but Idle problems ??
blup58 - June 24th, 2004 at 02:30 PM
G'day Guys/Girls
I have a plastic fuel filter between my fuel pump and carb on a stock 1600cc.
The fuel filter never seems to be full (always has about 1/3 full). Is this normal or should the Fuel filter be completely full. If it is meant to be full What tha??? is mine doing.
The engine runs great under throttle but pretty rough under idle (carby got rebuild last night which did improve this) but still a little rough
Thoughts??
Brad
[Edited on 28-6-2004 by blup58]
PurpleT3 - June 24th, 2004 at 02:58 PM
My fasty has a filter in the same spot, it's only ever 1/2 -3/4 full. She runs OK.
kombikim - June 24th, 2004 at 03:13 PM
1/3 full is quite normal
filter should be between tank & pump so that it is not subject to pressure
fuel shortage causes the opposite of the symptoms you describe
Dannyboy - June 24th, 2004 at 05:03 PM
Plus pressure can loosen the hoses if not careful and spray petrol over a hot engine. Move your filter out of the engine bay!!!!
Dan:)
blup58 - June 28th, 2004 at 03:33 PM
Thanks guys, relocated the fuel filter out of engine bay. Completely covered in fuel during process, didn't I smell a treat.
However, the engine is still playing silly buggers, under throttle, its great, but at idle sometimes good sometimes bad, quite often will just konk out. Makes sitting at the lights great fun......
Thoughts
kombikim - June 28th, 2004 at 03:43 PM
probably too rich, causing plugs to gradually foul up at idle, until they give up, let it idle until it stalls, or for 5 mins idling rough, & pull a few plugs,they be black if this is problem, to rich can be mixture or timing
vw139 - June 29th, 2004 at 04:25 PM
yeah I had the same on my 1600 > ended up being a very loose dizzy (replaced with 009) and air leakage around the carby throttle > fixed with an overhaul!
good luck
