I hope some one can help me .There is an old bug near my house ..going very cheaply ..Its 64 or 68 ish i think ?? Will any of the parts be compatible with my 72 superbug??Is it worth pulling it down to get parts eg engine gearbox etc.etc??
well not realy it s like going backwards in models . The engine if standard will only be a 1500 or 1300 and yours is twin port 1600 and u have irs
rear end (gearbox set up) and that 64-68 would be swing axel but ther is a big difrance between 64 -68 6 volt 1300 so on so on if this helps
It will have a Link Pin front end and yours is McPherson strut.
There is bugger all in common between the two cars.
thanks as you have saved me from hours of work on the spanners..cheers.
pass on the location someone else here may be able to use the parts
marcel
