just wondering how i can make my white walls flaps white again instead of yellowed and how to keep them white. is white vinyl spray the answer? any tips?
Jiff
any more info mate?
jiff and some 0000 steel wool, or the steel wool and any soap, polishes them up a little and removes some of the cracks that develop over time, they
are the ones trapping the dirt, maybe same 1500 grit paper or something instead of the wool but ive done the steel wool before
[Edited on 15-7-2004 by Adam_C]
thanks guys
White Vinegar,
Wipe on, Wipe off
Ive had these on my oval and the safest and best method of cleaning is:
Wax and Grease remover|Prepsol to clean.....then apply a silicon based tyre cleaner(Turtle Wax Tyre stuf was the best)
Do not sand as this will only create more 'tooth' for dirt to adhere to...
-W :thumb
tried the steel wool and jiff, cleaned it abit but there r some reall dark brown stains around the edges of the whitewalls that wont come off. any suggestions for heavy duty cleaning?
have u tried wd40 and lots of new , clean rags? Usually wiping it once then turning the rag helps. Stops you spreading the crap around.
Dan
white vynol spry makes them like new.
Mitchell
Mitchell
aluebrite its acid based but grate on rubber and even faded paint if u r quick with it dont leve it on 2 long tho
I used wd40 on mine today, sprayed on and just wiped off, worked very well.
