front beam disassembly
kombi_kid - December 26th, 2002 at 06:23 PM
hey
im currently pulling out the front beam out of my 72 kombi to fit adjusters.
everything is clear to pull out the beam but it is sticking to the chassis rails any suggestions?
and so i can knock the torsion bars out of the way to put in the adjusters i need to remove the torsion arms out etc.
can i pull this out as one with the brakes-torsion arms etc???? or do i have to do itr seperately??
and do i need to mark the position of the torsiob arm on the bar?
rhys
Buggy Boyz - December 26th, 2002 at 10:10 PM
Use a pinch bar between the rils and the beam, just leaver it down. If that dont work you can belt it with hammer. They are pain in teh ass.
You will find it much easier to pull the brakes off, then the stubs, then remove the arms followd by the leaves. You only need to do it to one side if you like.
kombi_kid - December 27th, 2002 at 05:55 AM
thanks brad!!!
rhys
KruizinKombi - December 27th, 2002 at 09:37 AM
They certainly are a pain. Lots of persistence required. Double check that you have removed all linkages and cables that run under or between the torsion tubes, and don't forget your brake hoses!
kombi_kid - December 27th, 2002 at 12:14 PM
hey everything is clear got of the ends know i just need to get it out!!!
rhys
kombi_kid - December 27th, 2002 at 04:10 PM
here are some pics of the front end out
kombi_kid - December 27th, 2002 at 04:12 PM
nother
kombi_kid - December 27th, 2002 at 04:13 PM
came out without any disputes!
kombi_kid - December 27th, 2002 at 04:14 PM
