Hello all,
I am helping a friend out by trying to get his Kombi running again.
First up the starter switch was intermittent - fixed.
Now there appears to be no spark. I have watched the dizzy spin whilst cranking and the points are arcing but when I take a lead off and ground it
there is no spark.
I then took the lead out of the top of the dizzy cap and held it near ground and it didn't produce a spark - so I thought faulty coil, but still same
thing with a good coil.
Obviously there is power going to coil as Cut-off solinoids working and points getting power but no spark from coil lead - and I have tried a good
lead too!
So....is there something I have missed, is there something that you can see I need to try as well.
[Edited on 6-8-2004 by Kombi M@D]
bad condenser???
rotor button ???? or as blue74l says
[Edited on 5-8-04 by pod]
Thanks guys,
It turned out to be a leaking Dizzy seal and failed condenser, oil had gotten into the dizzy and put a film onto the points.
Now running well
Thanks again.
