Total Seal Rings
PurpleT3 - August 16th, 2004 at 04:11 PM
Has any body used Total Seal Gapless Rings? I was thinking of using them on my stock 1600DP. Are they worth the extra money for this application or should I just stick to normal style rings?
Craig Torrens - August 16th, 2004 at 04:27 PM
yes to the first question............just use new normal style.
vw54 - August 16th, 2004 at 05:51 PM
If you need Total seal rings on a stock 1600 then your doing something wrong.
Just use the stock rings for a stock engine other wise your wasting valueable funds that could be used elsewhere.
