kombi front ends
kombi_kid - August 20th, 2004 at 06:02 PM
hey
is there any differrance between 72 and 76 model kombi front ends??? i have a 72 front end with adjusters that i would like to put into my 76 kombi i know that the brakes differ a little and i will simply just use a 72 bare beam and fit all 76 things to it??!?
rhys
Menangler - August 20th, 2004 at 08:47 PM
Rhys,
They are the same,
Although the early (I think pre '74 ish) had wider inner bushes, not the roller bearings the ones further in, the later ones were not as wide and it is quiet common to see skragged out arms where they had worn the inner bushes right away.
kombi_kid - August 22nd, 2004 at 10:44 AM
hey
thanks dave! i know them bushes are a pain is the arse as once there broken there is nothing you can do with the front end!! no one is reproducing them!
will see how we go!
rhys
wacked1 - August 22nd, 2004 at 02:50 PM
i think there is a diference on where the brake booster bolts on aswell. tho not too sure
