are front and rear wide 5 beetle drum brake internals inter changeable?
Anthiron - August 24th, 2004 at 08:47 PM
can i use the internals (cylinders, shoes + lining + springs adjusters etc) from front drums off a bug in the rear drums? is it the same gear?
Nick
silver - August 24th, 2004 at 09:13 PM
Should be!, the only difference being the handbrake lever, which clips on and off the shoes otherwise all the same......
vwking - August 24th, 2004 at 09:43 PM
sure can i have just done it
Anthiron - August 25th, 2004 at 07:58 AM
awesome thanks guys.
vw54 - August 25th, 2004 at 08:49 AM
I think the wheel cylinders are 19 mm on the front and only 17 on the rear.
vw54 - August 25th, 2004 at 08:54 AM
For got to say that on the later wide 5 the front shoes are wider than the rears.
Make sure that the adjuster screws match the ends of the brake shoes as well. as there are curved and flat type.
Desert Moose - August 25th, 2004 at 10:09 AM
Originally
posted by vw54
I'll run a tape over them before I send them for ya Nick.
