1500 manifold.... on a 1300?
Adam_C - August 28th, 2004 at 03:28 PM
will it fit? will the h30pict carb be better than the 28pict i have
Menangler - August 28th, 2004 at 05:46 PM
It will fit straight on, the only difference is the 1500 manifold is thicker by a tiny bit.
Adam_C - August 29th, 2004 at 12:06 PM
ok, i noticed the OD of the pipe was bigger, thanks
Klaus - August 29th, 2004 at 09:40 PM
check the main jet as a 1500 carb i bought new that i put on a 1300 i've got had a 120main where the 1300 had a 125main jet.. go figure.
