oil pressure question
seagull - September 29th, 2004 at 12:50 AM
I will be starting a new 1600 cc motor all new parts , what is the max of the oil pressure of a Vw motor its a 1300 cc case .
7 bar ?
Desert Moose - September 29th, 2004 at 01:38 AM
Someone will tell me I'm wrong but I think its about only 7psi at idle and 28psi to 30psi @ about 2500rpm ..
that is if your running a stock pump (1300)
at least this is a reply..........:P
Andy - September 29th, 2004 at 09:26 AM
Seagull, you should see ~6bar max for a stock setup (oil pump, std oil and stock relief) from memory.
*did* - September 29th, 2004 at 08:03 PM
I dont know but would like to know.
Here is a useful conversion thingy:
http://not2fast.wryday.com/turbo/boost_converter.shtml
seagull - September 29th, 2004 at 08:56 PM
O good I will have a pressure gauge at work for this .
