Semaphore Question
phantom - October 12th, 2004 at 09:38 PM
Are all VW Semaphores the same? All the pics I have seen in the past (never seen a real one) seem the same shape and size, so are they all the same? If you're looking for a set, can you simply buy any set of VW semaphores? Or...is it a case of having to buy for a certain model, etc?
Thanks....
oval TOFU - October 14th, 2004 at 12:12 AM
I'm pretty sure they are... but I have no grounds on which to make that assumption...
penguin - October 14th, 2004 at 07:20 AM
Not 100% sure, but I thought there were differences between the bus and beetle one.... but don't hold me to that.
vw54 - October 14th, 2004 at 07:21 AM
the ones we have here in Aussie are similar and will interchange
BUT There are differences in them some lens have 1 screw n some have 2 screws to attach...... the distance between the wiring terminals also vary .... 2 types as well
jnr356 - October 14th, 2004 at 11:05 PM
there are 2 makes SWF and SWO
phantom - October 15th, 2004 at 09:30 AM
If they are interchangable I'm happy......I'd like to know that if I pick up a set of VW semaphores that they will fit, rather than messing around with models, etc. Thanks all....
