externel oil cooler's
kombi_kid - November 1st, 2004 at 03:16 PM
hey guys
what sort of externel oil cooler best suits a kombi and where should it be located?????? pics would be great if possible!
rhys
kombi_kid - November 2nd, 2004 at 11:40 AM
so no one has one in there kombi's??? common guys!
rhys
kombikim - November 2nd, 2004 at 12:00 PM
I have & I found the thread in tech but the pohotos are gone
mine sits flat about 1/way up vehicle between heater tube & closest longitudinal "chassis" , it works so well that it has been wrapped in light sheet aluminium since about April to keep oil warm enough, unwrapping again soon though
BiX - November 2nd, 2004 at 12:10 PM
I found i had to put a alum plate over min in winter and wrap the lines in themo wrap to keep them warm, as it ran really cold.
nbturbo - November 2nd, 2004 at 01:08 PM
sounds like you need one of these to keep your oil temp up
nbturbo - November 2nd, 2004 at 01:09 PM
or one of these if you have a Type4-a bit neater fitting
kombikim - November 2nd, 2004 at 01:16 PM
yep, I need a thermostat of some sort, have a remote filter, that is underneath battery floor
kombi_kid - November 2nd, 2004 at 01:37 PM
so what sort of oil cooler did u use???? did u use a separate oil filter???? you obviously didnt need to run a thermo fan?
rhys
Chewy - November 2nd, 2004 at 02:24 PM
For the oil cooler I'd say get something like an auto transmission cooler from any late model car from the wreckers. Would be a hell of a lot cheaper than buying new.
Craig Torrens - November 2nd, 2004 at 02:39 PM
That's what the pressure relief valve is for in the oil circuit.
kombi_kid - November 2nd, 2004 at 03:10 PM
yer thatnks chewy everyone using 1/2" lines???
rhys
kombikim - November 2nd, 2004 at 03:16 PM
yep
kombi_kid - November 2nd, 2004 at 03:43 PM
kim can u draw a diagram of how it all plumbs up etc just so i get an idea of where it comes in and where it leaves for the cooler?
rhys
