back up lights 75 kombi
cutter16 - November 13th, 2004 at 07:32 PM
My Kombi doesnt have the socket for the reverse lights. Is it hard to solder new connection in and wire up? Tail lights and brakes work fine!! Any suggestions!!!
mnsKmobi - November 15th, 2004 at 01:22 PM
Could you give us a bit more info, please? Are you just missing the plastic bit that the globe plugs into (same as the other lights) or something else?
cutter16 - November 16th, 2004 at 04:11 PM
i suppose it would be the plastic bit that would have the connection for the wire at the back and the globe at the front. Do you know which colour wire connects in.
