1800 heads on 2lt ?????
pi22api22a - November 16th, 2004 at 02:41 PM
Hey all,,
Has anyone out there put 1800 heads onto a 2lt? I am working on an old 2lt, the heads are really bad so was considering using pair off an 1800.
Possible?
If so any othe mods needed?
Dave,,,,,:beer
mnsKmobi - November 16th, 2004 at 02:49 PM
AFAIK they bolt straight on. They're supposed to be an improvement over the 2l heads b/c they have bigger valves.
pi22api22a - November 16th, 2004 at 03:02 PM
Thanks, that'll save me a bit,, Heads on 1800 look pretty good still.
Any other parts exchangeable ?
Dave:beer
Bizarre - November 16th, 2004 at 03:43 PM
I think most of it
Andy - November 16th, 2004 at 10:07 PM
Crank, rods, pistons, barrels, flywheel, clutch are different.
The rest is the same pretty much.
Not sure on cam, push rods etc though.
Heads are straight swap.
MickH - November 16th, 2004 at 10:31 PM
The cam from the 1800 is a better option in the 2 liter if you are pulling the engine down but you will have to use the same lifters from the 1800 unless you get everything overhauled.I always ran the 1800 heads as they breath better with the larger valves.
pi22api22a - November 17th, 2004 at 08:23 AM
Thanks again for the advice, will help out heaps.
Just cracked the case in the 2lt, looks fine, have to replace camshaft + bearings. Then off to get all checked/measured.
Andy, the clutch off the 1800 looks pretty much the same as the 2lt, are they really different?
Dave:beer
KruizinKombi - November 17th, 2004 at 08:55 AM
2lt motors definitely had a bigger flywheel and clutch than 1800's, along with a different starter. I don't see any reason though why you couldn't use whatever you have.
Andy - November 17th, 2004 at 09:58 PM
As Kol said, the diameters are different. You need to match the flywheel to the GB. If you have a 2L GB, bell housing and starter, you need the 2L flywheel and clutch on the motor you put in it.
Hope that helps!
:thumb
