Questions for the Type3 Experts.....
Gibbo - November 21st, 2004 at 09:19 PM
Evenin all,
I have a couple of easy questions I hope for the type 3 experts among you.
1. How do I clean/clear the vents that lead down from just in front of the windscreen?
2. I seem to be getting water coming into the car via the heater channels, how can I stop/limit this happening?
3. I also seem to be having water pool in teh battery tray area. It seems to be coming from a hole in the rear seat front wall, see arrow on pic for direction of water. Where is this coming in from and how can I stop it?
Thanks all !!!
vw54 - November 22nd, 2004 at 06:38 AM
there are 2 rubber drain hoses on the air box. pull these off n blow or wash out, or remove the air boox and weld up the vent like it did.
more than likely it full of dirt n leaves some remove it and give a good wash out as well as the vent grate area
