wheel alignment
cray - November 24th, 2004 at 07:03 PM
gonna get a proper one done as soon as i can get to the place to do it, however to get there means i have to drive the car there. after putting in the
lowered front beam, new balljoints and a couple of other bits and pieces, the alignment is out of whack and it's scary to drive.
my dad wants to know if anyone can give him some instructions on how to do a rough wheel alignment on the front end just so we can get it to our local
guy without killing ourselves in the process.
ps. it's a '68 bj/sa beetle.
vw54 - November 24th, 2004 at 07:18 PM
Get a tape measure n measure the distance between the front edge of the front wheels n the rear edge of the front wheels
Adjust so theres only 2 or 3 mm difference and it will be good enough to drive.
Of couse drive carfully n not to fast
The mechanical shop in front of Vintage at Campsie has a 4 wheels aligner.... they do a good job
cray - November 24th, 2004 at 07:34 PM
Originally
posted by vw54
i'll be taking it up to peter in riverstone, the car's in blacktown and i'd rather not drive all the way to campsie without a proper alignment, but
thanks heaps for the info
vw54 - November 24th, 2004 at 07:36 PM
yeah Ok just try and get both wheels pointing somewhere near straight then measure and adjust
Are all the tie rod end greased up so they turn easy.??
vw54 - November 24th, 2004 at 07:37 PM
If you can get it on one of the 4 wheels aligners there really good especially if you have played around with the rear end .
cray - November 24th, 2004 at 07:37 PM
Originally
posted by vw54
yep
cray - November 24th, 2004 at 07:38 PM
Originally
posted by vw54
haven't touched the rear end at all and it had a four wheel alignment about 300kms ago. it's just that that 300kms ago was back in 2001.
