accelerator pedal linkages
kitekombi - December 2nd, 2004 at 08:30 PM
My linkages are stuffed on my 73 micro'. Has any one found good aftermarket ones or do i need to try and make my own??
kombibob - December 2nd, 2004 at 08:35 PM
why kitekombi your not a kitesurfer are you?
kitekombi - December 2nd, 2004 at 08:38 PM
sure am. Best thing ive done..so far
kombibob - December 2nd, 2004 at 08:49 PM
me too i'm a team rider for caution kites where are you from?
11CAB - December 2nd, 2004 at 08:59 PM
Go down to the wreckers and get the linkage assembly from a 77 or later kombi. The pedal is stronger, the linkage pushes straight unlike the earlier ones and the linkage goes across in front of the steering column instead of behind like the earlier ones so you can tell the difference.
57 Chook Shed - December 5th, 2004 at 02:48 PM
I`ve got the same problem with my `73 Crewcab.
I tightened it up a bit using some washers in between the flat parts of the linkage and the spring clips that hold them in place. Looks like the hole in the bracket that is welded to the floor has worn oval. I`m getting about 2/3 throttle because of all the wear.
I`m going to cut the bracket off and weld in a couple of washers or a small tube to make the holes round again. I doubt I`ll find a better one at the wreckers.
Graham.
[Edited on 5-12-2004 by 57 Chook Shed]
kitekombi - December 6th, 2004 at 11:55 AM
kombibob, Im in Melbourne. Ride a 12m fuel and a 16m Aero2:beer
