Just got home
lugnuts - January 24th, 2003 at 03:39 AM
3.50am.But and this is a flashback it was 1.50am and i was going home through Strathfield accelerating up hill when all of a sudden cough fart hiccup cough another cough and i thought hello hello whats going on,engine was still running but very rough like 2 outa 4 cyls so i scanned the horizon looking for the next exit and coughed to a halt.It would start but not idle so i started pulling leads off 2 at a time still the same or so it sounded anyway after an hour of checking my wife turned up and then i found i had spark to all plugs and fuel to the accelerater pump but still running rough,i thought it might have been some dud fuel id filled up the day before and had removed my fuel filter.And then it wouldnt start at all bull**it,the starter relay was working so it could be the starter solenoid,yep sure enough the plug came off and when i was playing with the wiring it must have pulled it away instead of just touching.Anyway kicked her over ran rough for a minute then bingo its 3.35am.:D
kombi_kid - January 24th, 2003 at 06:37 AM
try the idling wire that prolly what it is the one going to the solenoids and hooks onto your coil (dont know which side) it happened to use before!!
rhys
