Introduction & crankshaft balancer wanted
FlyVW - December 21st, 2004 at 11:35 AM
Hi All:
My name’s Norm and I live near Cairns, FNQ. I’m building an aircraft engine based on a Type-1 crankcase. I’m at the stage where I need to get the crankshaft dynamically balanced.
The crankshaft is slightly different. The pulley end is machined for a propeller hub. It has a 3-degree taper and a keyway. The prop hub has a matching 3-degree taper and keyway. A special long “Pulley bolt” is used to hold the hub in place.
The clutch end has a specially lightened flywheel. Bolted to the centre of the flywheel is a magnetic ring that is part of the alternator and used in the charging system.
The whole thing (hub, crankshaft, flywheel, and magnetic ring) needs to be bolted together to form a unit and dynamically balanced to a high degree of precision.
Is there anyone up in my area (FNQ) that can dynamically balance my crankshaft? Perhaps they have balanced Formulae-V or Porsche racing engines - someone that would put in that extra effort to make it perfect. Any recommendations?
If there is no one up in this area, who would be the closest?
Norm
Bizarre - December 21st, 2004 at 11:58 AM
Hi there
welcome aboard
You are doing different stuff - most airplane engines are based on Type 4 motors.
The 2 companies below do airplane stuff - not close but shipping is no problem. Details were cut and pasted from the Oz Buisness Directory in the link in the front banner
Conti Engines / Volks Heads
2/15 Armitage St Bribie Island Qld Ph 3408 3103 The largest Excahnge VW engine builder in Australia. Very cheap rates and a 12 mth 20 000km warranty on all recondition engines. Give Gary a call, great shipping rates Australia wide
Stan Pobjoy
1252 Orara Way NANA GLEN Via COFFS HARBOUR NSW 2450 Ph: 02 6654 3694
Hope you find someone to help you
TTFN
Barry
