empi trigger shifter instalation....
pyr0 - December 26th, 2004 at 08:51 PM
ok guys got the shifter in my kombi i got it 4 chrissy :)
anywho i found i had to use the bigger spacer it came with, all is well accept i dont need to pull the trigger up to enguage reverse i can just select it.
so heres what im thinking, 1st up i tooik the shift plate out when i installed the new shifter, should i of left this in ???
and help is greatly appreciated :sandrine
VWFREAK - December 26th, 2004 at 09:04 PM
You'll need longer bolts, 10mm longer. put the car in 3rd gear and install new shifter. 1 for 1 that easy.
Make sure it changes smoothly before fully tightening up the bolts.
Happy shifting
pyr0 - December 26th, 2004 at 09:14 PM
i got new bolts they came with the shifter ;)
but i dont have the shift plate in there any more :duh: should i put that back in ??
(my shifter was a new one or nos or whatever but it came in the packing still :) )
pyr0 - December 26th, 2004 at 10:14 PM
bumporooney :bounce
*did* - December 27th, 2004 at 11:13 AM
put it in and see what happens, if you cant see any type of reverse lock out mechanism on the new shifter assembly then i guess it just uses the normal one
Menangler - December 27th, 2004 at 04:57 PM
With the Empi trigger shifter you don't need the original plate,
The shifter should have come with 2 different spacers, the instructions tell you what one to use, bolt it in and it should work, check the adjustment, and make sure it selects all gears.
Shouldn't select reverse with out lifting the trigger, if it does, pull it out and check the bottom of the shifter, and you will see how the lock out works.
I just fitted one to my '74 twin cab as the old shifter was worn, and it shifts like a new car.
Good luck
Buggyboy - December 27th, 2004 at 07:17 PM
Sorry to interrupt but it sort of related. I need a new shifter for my dual-cab, have got the a new little rubber bush, though I know it needs a new gate, so will do both at the same time.
But how much are these Empi shifters and where from ? I have seen one in a bug- do they look the same ?
kombi_kid - December 27th, 2004 at 07:59 PM
yer they look the same just taller for a bus im not sure on a price ask buggybrad or dave becker
rhys
Menangler - December 28th, 2004 at 11:34 AM
Classic have them for $180.00 I think, I had mine 4 sale for $150.00 but have decided to use it now.
