Temp Sender Woes
Davecho - February 4th, 2005 at 05:54 PM
Can someone please help me out.
I bought a oil temp guage and sender and am wondering where to put it! I know that it has to be drilled and tapped into the sump. but where? Can someone help me out with this or if anyone is able to do it for me it would be much appreciated! Will pay for it of course.
We are heading off in 2 weeks to travel australia and it would be very handy to have the oil temp guage fitted..
Cheers Dave
Davecho - February 4th, 2005 at 07:01 PM
Is there a factory sender which goes to the oil light on the dash that i would take out and but the new one in (changing thread or whatever).
Or with the right adapter could it be made to fit the drain plug??
:alien
Davecho - February 4th, 2005 at 07:16 PM
Just reading about putting one in the oil pressure relief plug?? Just wondering where this is found (i've usless with vw motors) and also what size thread it is?
greedy51 - February 4th, 2005 at 07:35 PM
mate did that been there the best place is in the removable sump the round steel bit and that can be taken to someone that can braise it in for ya mine worked fine good luck
manxed69 - February 4th, 2005 at 10:53 PM
I'll try and get you a photo tomorrow. In my 1600, mine was put in the case to the right of the rear pully down low. You wont need the adaptor if you can get the right size tap for the sender unit. I hope that you know what the thread is as VDO had about five different sizes.
manxed69 - February 4th, 2005 at 11:04 PM
I am impatient so here's the photo.
[Edited on 4-2-2005 by manxed69]
